GT
Bypass Graphic card check for GT Designer
Joined: 1/11/2023(UTC) Posts: 12  Location: Berlin Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Hello Martin , Please how it is possible to bypass graphic card check for the GT designer , we need urgently to update some text in our GT project , but since we are using a laptop that have no compatible graphic card , we need to bypass the GT designer graphic card check , please how it is possible to do so , we need this to work urgently just to open the GT designer and only update some text . thanks
Originally Posted by: BrixxNatt  Hello Martin , Please how it is possible to bypass graphic card check for the GT designer , we need urgently to update some text in our GT project , but since we are using a laptop that have no compatible graphic card , we need to bypass the GT designer graphic card check , please how it is possible to do so , we need this to work urgently just to open the GT designer and only update some text . thanks If all you want to do is change some text: rename the Gtzip file to a zip file and extract. Edit the document.xml with a texteditor and save turn all the previous extracted files back into a zip archive and rebname it back to a .gtzip Maybe next time edit the gt title properly and turn the text that needs to be change into an editable textfield within the title so one can change the content with the editor
Thanks for the advice , but changing text also need to change some position , I hope that there is a bypass for graphic card check for the GT , only to edit some stuff on the fly
Originally Posted by: BrixxNatt  Thanks for the advice , but changing text also need to change some position , I hope that there is a bypass for graphic card check for the GT , only to edit some stuff on the fly one can chaange positions too in the XML i mentioned, as are colors and more (see allready more than initially wanted for, whats next? ) Doubt a bypass will be available ever as its full functioning is related to high end license and related to the graphics card in use (be it for edit as use of the title) IMO edits on the fly means on the licensed working machine ;-)
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
There is no graphics card check to remove. GT Designer needs a graphics card in order to work at all. Sorry about that.
GT
