Smidddy
#1 Posted : Wednesday, January 11, 2023 7:51:17 PM(UTC)
Smidddy
Austria
Hello everyone,
I'm looking for hint how to realize a draw application in Vmix.
I would like to have a possibiliy to let a grafik (Text+ Logo) which is shown in some kind of group or roster, disapear in this group/roster and appear on another predefined space.
Issue here is that there are multiple possibility's where the grafik could appear.
Anybody has an idea, how and if this is possible?
Thank you!
Cheers Peter
zenvideo
#2 Posted : Wednesday, January 11, 2023 8:21:08 PM(UTC)
zenvideo
I'm not sure that you're going to be able to do it "in vMix", but you might want to look at using an external application like Panamation to generate the animated graphics, which would then feed into vMix via NDI (typically from a separate PC).
jpetrie on 1/18/2023(UTC)
