GT
Move to next line in data source after ticker end
Joined: 1/9/2023(UTC) Posts: 7  Was thanked: 1 time(s) in 1 post(s)
Is there a way to set a data source used by a ticker to change to the next row after the ticker finishes scrolling the text? For example, if row 1 contains a sentence, at the end of the sentence move to row 2, and so on.
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Scar7752  Is there a way to set a data source used by a ticker to change to the next row after the ticker finishes scrolling the text? For example, if row 1 contains a sentence, at the end of the sentence move to row 2, and so on. No. on the other hand one can make a script to read the current content of the ticker ,calculate based on the length of the text and the ticker speed the duration for the text to finish its pass to then instruct to go to the next row
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
I know you are in the GT forum, so sorry for this, you could at least try with a xaml I tried this in a basic xaml ticker where I removed the automatic repetition, basically it is a ticker that has no repetition
create a simple data source in my case an excel csv autonext disabled 1 second update and loop enabled
in the ticker triggers put 3 of them all with the OnCompletion event the first put datasourceautonextON the second put datasourceautonextOff but we give it a delay of 1000, so it takes time to go to the next row the third play this in the ticker input.
Translated from Spanish to English by Google
GT
