Systems
Startech 4 POE PCI CARD - only 1 NDI feed visible
Hey! I have this Startech 4 port POE Gigabit PCI card installed in my AMD based pc: https://www.startech.com...tworking-io/st4000pexpseI connect and power 3 Birddog P200's from the card. But when opening VMIX I only see 1 camera. The IP addresses are correctly setup, because I can acces all three camera's via the webbrowser. Is this a hardware limitation from the PCI card? I'm using the latest version of VMIX 25. In CamControl I can also only see one camera. Any ideas? Thanks!
FIXED Just went into NDI manager and then went to the advanced tab > Network mapping > Discovery server (filled in every IP of all 3 PTZ's). And now I can control and add them over NDI in Vmix 🙂
Systems
