DataSourceSelectRow and Dynamic Value
Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
Hi, I'm using a MIDI shortcut note ON to SetDynamicValue=2 Then Midi note OFF (same note) tp DataSourceSelectRow= MYDSN,Sheet1,Dynamic4
But this does not work, it appears that you cant use the Dynamic variable in this way, unless I am doing something wrong?
Rank: Staff
Groups: Registered, Moderator Joined: 8/15/2017(UTC) Posts: 69 Location: Canada
Thanks: 1 times Was thanked: 22 time(s) in 21 post(s)
@ nowski
"Dynamic4" is not going to be recognized as an "index" value for your Data Source row, this needs to be an actual number starting at "0" that corresponds to the row your desired data is in, so in other words, not variable with the Dynamic Value feature in vMix.
vMix Greg
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: nowski  Hi, I'm using a MIDI shortcut note ON to SetDynamicValue=2 Then Midi note OFF (same note) tp DataSourceSelectRow= MYDSN,Sheet1,Dynamic4
Thanks MYDSN,Sheet1,Dynamic4 is a string , cant combine the first part of the string with the value of the DynamicValue within the shortcut value part In scripting you will need to pull the dynamic value first and convert it to a string to add to the "MYDSN,Sheet1," part Has been mentioned in this forum for sure Specifying SetDynamicValue4=MYDSN,Sheet1,2 then DataSourceSelectRow=Dynamic4 will work to btw need to specify which Dynamic value one is setting too
Yes thanks, figured it out eventually, but now trying to search a string value in a dynamic value, it appears that InStr(string, substring) not supported? Or is it another example of my ineptitude. Trying to test for characters in the Dynamic4 variable....
Originally Posted by: nowski  Trying to test for characters in the Dynamic4 variable....
vb.net !! Try this
