2 Pages<12
Ario
#21 Posted : Tuesday, December 27, 2022 6:07:17 AM(UTC)
Ario
Was thanked: 20 time(s) in 17 post(s)
+1
So many +1's ... am I right that this request was never implemented?
It deserves serious consideration.
PeterH
#22 Posted : Wednesday, December 28, 2022 11:50:30 PM(UTC)
PeterH
+1
jip
#23 Posted : Tuesday, February 28, 2023 5:33:26 AM(UTC)
jip
Estonia
+1
melody
#24 Posted : Wednesday, March 1, 2023 2:27:31 AM(UTC)
Rank: Guest
Groups: Guests
+1
avsoundguy
#25 Posted : Wednesday, March 1, 2023 5:43:54 AM(UTC)
avsoundguy
+1
WaltG12
#26 Posted : Wednesday, March 1, 2023 6:06:22 PM(UTC)
WaltG12
+1
Originally Posted by: Ario Go to Quoted Post
+1
Just because an idea--especially a popular one--has not been implemented doesn't mean it hasn't been (or isn't being) seriously considered.
jpratchett
#27 Posted : Thursday, May 11, 2023 11:55:00 PM(UTC)
jpratchett
+1
RichDanby
#28 Posted : Friday, May 12, 2023 3:16:28 AM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
This sounded like an interesting challenge so I've just written a PowerShell script that will monitor a folder and add new files to a list input - it doesn't handle files being deleted or renamed. I say I wrote it but it is 90% from a file monitoring example I found.
At the top of the code you need to set the input number of the list you want files added to and also the path to the folder you want to monitor.
To run it, open Windows PowerShell, and paste the script in and press enter. It outputs a . every second to show it is doing something and will display a message when a new file is found.
Hopefully this helps some of you out, or can be a starting point.
Code:
# values to set
# specify input you want the files added to
$ListInput=2
# specify the path to the folder you want to monitor:
$Path = "C:\WatchFolder"
# specify which files you want to monitor
$FileFilter = '*'
# specify whether you want to monitor subfolders as well:
$IncludeSubfolders = $false
# create TCP connection to vMix API
$tcpConnection = New-Object System.Net.Sockets.TcpClient(127.0.0.1, 8099)
$tcpStream = $tcpConnection.GetStream()
$writer = New-Object System.IO.StreamWriter($tcpStream)
$writer.AutoFlush = $true
# folder monitoring coded based on https://powershell.one/tricks/filesystem/filesystemwatcher#advanced-mode-asynchonous
$AttributeFilter = [IO.NotifyFilters]::FileName, [IO.NotifyFilters]::LastWrite
try
  $watcher = New-Object -TypeName System.IO.FileSystemWatcher -Property @{
    Path = $Path
    Filter = $FileFilter
    IncludeSubdirectories = $IncludeSubfolders
    NotifyFilter = $AttributeFilter
  # define the code that should execute when a change occurs:
  $action = {
    # the code is receiving this to work with:
    # change type information:
    $details = $event.SourceEventArgs
    $Name = $details.Name
    $FullPath = $details.FullPath
    $OldFullPath = $details.OldFullPath
    $OldName = $details.OldName
    # type of change:
    $ChangeType = $details.ChangeType
    # when the change occured:
    $Timestamp = $event.TimeGenerated
    # now you can define some action to take based on the
    # details about the change event:
    # let's compose a message:
    $text = "{0} was {1} at {2}" -f $FullPath, $ChangeType, $Timestamp
    Write-Host ""
    Write-Host $text -ForegroundColor DarkYellow
    # you can also execute code based on change type here:
    switch ($ChangeType)
      'Changed'  { "CHANGE" }
      'Created'  { "CREATED"
        # add file to list
        $command = "FUNCTION ListAdd Input={0}&Value={1}" -f $ListInput, $FullPath
        $writer.writeLine($command)
      'Deleted'  { "DELETED" }
      'Renamed'  { "RENAMED" }
      # any unhandled change types surface here:
      default   { Write-Host $_ -ForegroundColor Red -BackgroundColor White }
  # subscribe your event handler to all event types that are
  # important to you. Do this as a scriptblock so all returned
  # event handlers can be easily stored in $handlers:
  $handlers = . {
    Register-ObjectEvent -InputObject $watcher -EventName Changed  -Action $action
    Register-ObjectEvent -InputObject $watcher -EventName Created  -Action $action
    Register-ObjectEvent -InputObject $watcher -EventName Deleted  -Action $action
    Register-ObjectEvent -InputObject $watcher -EventName Renamed  -Action $action
  # monitoring starts now:
  $watcher.EnableRaisingEvents = $true
  Write-Host "Watching for changes to $Path"
  # since the FileSystemWatcher is no longer blocking PowerShell
  # we need a way to pause PowerShell while being responsive to
  # incoming events. Use an endless loop to keep PowerShell busy:
  do
    # Wait-Event waits for a second and stays responsive to events
    # Start-Sleep in contrast would NOT work and ignore incoming events
    Wait-Event -Timeout 1
    # write a dot to indicate we are still monitoring:
    Write-Host "." -NoNewline
  } while ($true)
finally
  # this gets executed when user presses CTRL+C:
  # stop monitoring
  $watcher.EnableRaisingEvents = $false
  # remove the event handlers
  $handlers | ForEach-Object {
    Unregister-Event -SourceIdentifier $_.Name
  # event handlers are technically implemented as a special kind
  # of background job, so remove the jobs now:
  $handlers | Remove-Job
  # properly dispose the FileSystemWatcher:
  $watcher.Dispose()
  Write-Warning "Event Handler disabled, monitoring ends."
thanks 1 user thanked RichDanby for this useful post.
Ario on 10/24/2025(UTC)
TL68
#29 Posted : Friday, October 17, 2025 10:24:12 PM(UTC)
TL68
Sweden
+1
...cannot understand why such an obvious and very useful function still is missing in vMix.
ventura
#30 Posted : Friday, October 24, 2025 11:25:22 PM(UTC)
ventura
Portugal
1+
mavik
#31 Posted : Friday, October 24, 2025 11:39:01 PM(UTC)
mavik
Was thanked: 193 time(s) in 173 post(s)
+1 I can see a use of it.
2 Pages<12
