3rd Party Software and Development
Switch Joystick controll on/off via API or script
Hey there, I want to know if there is a way to switch the joystick controll on/off by script or by API. That would be very nice for my setup. Maybe you can help me out with a short command :-)
Thank you all, Alex
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: alexkuehl  Hey there, I want to know if there is a way to switch the joystick controll on/off by script or by API. That would be very nice for my setup. Maybe you can help me out with a short command :-)
Thank you all, Alex what Joystick? Does it have commands of its own? What are you controlling with it? Have you checked the "Shortcut Function Reference list" in the helpfiles?
I want to trigger the little Checkbox in front of a row in the joystick settings of vMix to activate or deactivate the row. Is there a way?  Screenshot 2022-12-29 005344.png (25kb) downloaded 0 time(s).
Originally Posted by: alexkuehl  I want to trigger the little Checkbox in front of a row in the joystick settings of vMix to activate or deactivate the row. Is there a way?
Well one could call a script to perform the function instead that checks maybe a DynamicValue value set with another shortcut to allow the function to happen or not
