Hi Martin,
Am having trouble connecting to Twitter. Everytime I go to logon I get the following error message:
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.Net.WebException: The remote server returned an error: (401) Unauthorized. at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) at System.Net.WebClient.UploadString(Uri address, String method, String data) at System.Net.WebClient.UploadString(String address, String data) at vMixSocial.OAuthClient.GetResponse(Uri url, String method) at vMixSocial.TwitterDataSource.Login() at vMixSocial.frmTwitterSettings.cmdLogin_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5477 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
vMixSocial Assembly Version: 1.0.0.44 Win32 Version: 1.0.0.44 CodeBase: file:///C:/Program%20Files%20(x86)/vMixSocial/vMixSocial.exe
Microsoft.VisualBasic Assembly Version: 8.0.0.0 Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Web Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.5483 (Win7SP1GDR.050727-5400) CodeBase: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Please make sure the latest version of vMix Social is installed. There have been a few updates since 1.0.0.44
Hi from Spain.
Can somebody help me with this?
Consulte el final de este mensaje para obtener más detalles sobre cómo invocar a la depuración Just-In-Time (JIT) en lugar de a este cuadro de diálogo.
************** Texto de la excepción ************** System.Net.WebException: Error en el servidor remoto: (404) No se encontró. en System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) en System.Net.WebClient.UploadString(Uri address, String method, String data) en System.Net.WebClient.UploadString(String address, String data) en vMixSocial.OAuthClient.GetResponse(Uri url, String method) en vMixSocial.TwitterDataSource.Login() en vMixSocial.frmTwitterSettings.cmdLogin_Click(Object sender, EventArgs e) en System.Windows.Forms.Control.OnClick(EventArgs e) en System.Windows.Forms.Button.OnClick(EventArgs e) en System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) en System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) en System.Windows.Forms.Control.WndProc(Message& m) en System.Windows.Forms.ButtonBase.WndProc(Message& m) en System.Windows.Forms.Button.WndProc(Message& m) en System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) en System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) en System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Ensamblados cargados ************** mscorlib Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9151 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
vMixSocial Versión del ensamblado: 6.0.0.16 Versión Win32: 6.0.0.16 Código base: file:///C:/Program%20Files%20(x86)/vMixSocial/vMixSocial.exe
Microsoft.VisualBasic Versión del ensamblado: 8.0.0.0 Versión Win32: 8.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9153 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9151 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
System.Web Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9161 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_32/System.Web/2.0.0.0__b03f5f7f11d50a3a/System.Web.dll
System.resources Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.resources/2.0.0.0_es_b77a5c561934e089/System.resources.dll
System.Windows.Forms.resources Versión del ensamblado: 2.0.0.0 Versión Win32: 2.0.50727.9149 (WinRelRS6.050727-9100) Código base: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_es_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Depuración JIT ************** Para habilitar la depuración Just In Time (JIT), el archivo de configuración de esta aplicación o equipo (machine.config) debe tener el valor jitDebugging establecido en la sección system.windows.forms. La aplicación también se debe compilar con la depuración habilitada
Por ejemplo:
Cuando esté habilitada la depuración JIT, cualquier excepción no controlada se enviará al depurador JIT registrado en el equipo en lugar de controlarlo mediante el cuadro de diálogo.
Thanks anyway
