mp
#1 Posted : Tuesday, December 20, 2022 2:35:01 AM(UTC)
mp
Hi guys,
I have tried to search the forum for the answer, however no success.
My question is, when I am outputing external renderer -->Blackmagic Declink mini monitor, do I have to match the output with my vmix preset?
Usually I have my preset 1080 25p, however for my next project they told me, that I should send them 1080 50i. Is it going to be ok, if I just change the output renderer setting to 1080 50i, or it would be better if I make a new vmix project 1080 50i?
Or maybe if I turn around the question. Can vmix convert without dropping frames or any other problem 25p to 50i, or maybe also 50p to 50i and send it correctly to Declink mini monitor?
nikosman88
#2 Posted : Wednesday, December 21, 2022 11:34:08 PM(UTC)
nikosman88
Greece
Hello external renderer in bmd device can have different output from your display preset.You can do what you need. You can make test to see what happens. Im doing something similar. Im sending 576 50i to intensity 4k and im streaming 108025p without problem. My preset is 1080 50i
