Hardware Compatibility
Magewell Eco Capture Quad SDI M.2 with embedded audio chanels
Thanks: 38 times Was thanked: 24 time(s) in 20 post(s)
Hello Guys,
I have a question regarding the Magewell Eco Capture Quad SDI M.2 card...
1., Has anyone tried this Magewell card with VMIX? Is it supported, working well? 2., I didn't found any information regarding the supported embedded audio channels. How many supported (in VMIX)? 2ch? or more, 8/16ch?
I try to found the right M.2 solution wiht multiple SDI input (2-4ch SDI) with multi channel audio (at least with the first 8ch audio).
Thanks for all the tips and ideas!
