filmmaker
#1 Posted : Monday, November 21, 2011 6:25:47 AM(UTC)
filmmaker
Hello Martin, and hello to the whole community.
I open another post to ask for confirmation of my new PC configuration.
The need is to acquire two analog sources, and analog out. With three "Blackmagic Intensity Pro" I can do this? With these three cards in the future I might work in HDMI? sources can be mixed in and out?
For example: two HDMI inputs, recording on Hard Disk vMix, analog composite output to a screen.
And to do this, this PC work?
- ALI LC-POWER 500W
- MoBo Gigabyte GA-Z68XP-UD3
- CPU i5-2300 boxed
- RAM DDR3 Corsair xms3 8Gb (2x4 in Dual Channel mode)
- Nvidia GTX550 1Gb
- HDD Samsung SpinPoint F3 500Gb (for S.O. e software only)
- 2 x HDD Samsung SpinPoint F3 1TB in RAID 0 (for video recording)
- 3 x BlackMagic Intensity PRO
All mounted in a rack-mount industrial chassis
The mobo has two firewire ports be used simultaneously (tested).
One other question ... IF I WOULD INCREASE THE INPUTS? I have to find a Mobo with multiple ports PCI-Ex and mount other BMI?
Thanks to you and all those who wish to respond.
#2 Posted : Monday, November 21, 2011 7:49:09 AM(UTC)
Was thanked: 4788 time(s) in 1643 post(s)
Yes, you can use as many Intensity Pro cards as you like.
I recommend using the second output of the graphics card for the output to the screen as there will be a delay if you use the Intensity Pro output.
(This is an Intensity Pro limitation as the output is designed for recording)
There are many motherboards out there with 6x PCI-Ex slots such as:
http://www.asus.com/Moth...1366/P6T6_WS_Revolution/
filmmaker
#3 Posted : Monday, November 21, 2011 8:08:54 AM(UTC)
filmmaker
I wanted to know if I can use the analog output of the Blackmagic to send the composite signal to an uplink. is difficult for an uplink accepts a DVI signal. The exit delay is not important.
Thanks for the tip on the motherboard;)
The rest of the configuration is ok? Or do I need an i7?
