vMix Call
VMIX Call without Cam
Joined: 2/18/2019(UTC) Posts: 58  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hi!
I'd like to have a vmix call opened for my Co-Commentator, because thats the way to give them live stream without latency.
These commentator has no obs and no webcam. I get his audio signal via Discord. He just needs to see my output signal so we can talk about what's happening at the same time. Unfortunately, he still needs a camera so that advanced vmixcall starts.
Which virtual camera driver would you recommend? It should only be selectable in the Vmixcall settings and can do nothing else.
The smaller the better. So far I've only found Cyberlink YouCam, but that's 600MB in size. It has to be smaller and quick and easy to set up for spontaneous co-commentators.
Thank you i.a. Burie
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 98 time(s) in 94 post(s)
Rank:: Advanced Member
Joined: 3/17/2017(UTC) Posts: 454  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 58 time(s) in 52 post(s)
This works with any cheap webcam.
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
Originally Posted by: elvis55  This works with any cheap webcam. This work with any smartphone. But it also installs camera driver so if dont you connect any phone,programms (and vmix call) will recognise it like a real camera,so it will done what you need without the need to have a real camera
Originally Posted by: nikosman88  See droidcam thank you Originally Posted by: elvis55  This works with any cheap webcam. once more: he has no webcam, and he also will not buy one, not for these one or two cocommentator sessions... Originally Posted by: Salvatore  NDI Tools Oh, right, NDI has a virt Webcam... I think I prefer this solution. Thanks!!!!
vMix Call
