ChrisG_NRN
#1 Posted : Thursday, December 15, 2022 1:38:31 AM(UTC)
ChrisG_NRN
You have been a member since:: 4/9/2021(UTC)
I hope this makes sense. I'm putting together a master template for our productions to use, and one thing we do a ton of is virtual inputs. We'll take a master shot of two hosts on the same mobile camera and create two separate virtual inputs of the hosts individually for use in ATEM SuperSource like transitions utilizing mix busses. Unfortunately, there isn't an option to create a virtual input from the full menu; only from the input settings screen. This creates a new input that goes at the end of the line. If we could create a virtual input from the menu, that would give ops the ability to change a bars/holding input into a virtual input similar to changing it to another type of input. If this sounds like gibberish, let me know and I'll try to explain it better. Cheers!
