Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Hi guys, Pls tell me it is possible to setup input from XTV Suite software? I see that in Adobe Flash Media Live encoder I see MediaLooks video output (from XTV) but I can add it in vMix. Thanks!
Joined: 3/7/2012(UTC) Posts: 2,682  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ cowan
Not sure I understand your workflow??? Can you explain what you want to do a little better?
Sorry, my first language is Czech. I have fix the problem. Let me explain that. We use a XTV suite for broadcasting 24x7 but in our version it doesn't support streaming to RTMP server. We have installed vMix and tried to setup input channel from XTV (because it has vitrual video and audio outputs). But in vMix I haven't founded it in Camera menu. After that in this forum I have found that I need to use vMix x32 version because XTV is 32-bit software. It is very important!!! Now I have successfully setup vMix input from XTV and streaming to our RTMP server. Hope my experience will usefull for all :)
Originally Posted by: cowan  Sorry, my first language is Czech. I have fix the problem. Let me explain that. We use a XTV suite for broadcasting 24x7 but in our version it doesn't support streaming to RTMP server. We have installed vMix and tried to setup input channel from XTV (because it has vitrual video and audio outputs). But in vMix I haven't founded it in Camera menu. After that in this forum I have found that I need to use vMix x32 version because XTV is 32-bit software. It is very important!!! Now I have successfully setup vMix input from XTV and streaming to our RTMP server. Hope my experience will usefull for all :) I have the same problem as you, but I can’t figure out how to connect xtv suite via ndi to vmix. Persistently vmix does not see ndi I did not find the 32 bit version.
Still found a 32 bit version. But I don’t understand how to connect them in the settings. It turns out only the sound. Can someone help in resolving the issue?
Originally Posted by: Re-Aktor  Still found a 32 bit version. But I don’t understand how to connect them in the settings. It turns out only the sound. Can someone help in resolving the issue? Hi! May I ask what software are you currently using? Unfortunately, the problems of automating vMix have not been solved yet.
