Jiraka7
#1 Posted : Tuesday, January 25, 2022 2:31:04 AM(UTC)
Jiraka7
Czech Republic
I would really appreciate the option to add output or preview to Multiview like other inputs.
I would like to use Multiview instead of the fullscreen feature because it has more optimizations, combination of inputs and the ability to use NDI.
It would be great if this option would be added in the next version, or does anyone know any solution how to do this.
thanks 1 user thanked Jiraka7 for this useful post.
lanceyoder on 11/9/2022(UTC)
Roy Sinclair
#2 Posted : Thursday, January 27, 2022 8:25:23 AM(UTC)
Roy Sinclair
Was thanked: 32 time(s) in 28 post(s)
If you turn on the NDI option for an output that makes it available as an NDI Input that you can then put into a multiview.
jeepndave
#3 Posted : Wednesday, December 14, 2022 1:14:48 PM(UTC)
jeepndave
+1
With color outline for preview and output.
Plus show color outline/border on inputs in Multiview to show which is in preview and output.
More options in customize Multiview.
I would like to make fullscreen 1 with output and some inputs and have output show with a colored outline/border and the input that is in output have the colored outline/border also.
And fullscreen 2 with preview and some inputs and have preview show with a colored outline/border and the input that is in preview have the colored outline/border also.
And be able to add the audio meters to the Multiview.
