fideba
#1 Posted : Tuesday, December 13, 2022 1:41:00 AM(UTC)
fideba
I'm trying to use a stinger I've purchased (gtzip format). Whenever, in vMix, I select any stinger (1 to 3) in the overlay menu, and I select the Stinger input I've created (Title/XAML), the opions "Duration" and "Stinger Cut Point" disappear, making the stinger unusable.
Any ideas ?
Thanks !
#2 Posted : Tuesday, December 13, 2022 2:47:01 AM(UTC)
Hard to say without knowing your "stinger"file, but likely not a stinger capable gtzip file ( containing some sort of animation/duration or simply because it has a build in in/out animation with fixed duration like the ones that come with vMix
Have you actually tested its function or is your question just based on the settings not being available ?
