mcmcomp
#1 Posted : Sunday, December 11, 2022 3:42:37 PM(UTC)
mcmcomp
I was using NDI in vmix with another computer running NDI screen capture. vMix stopped accepting or reading the screen capture from the other computer. I tried during the stream to restart the second computer NDI capture with no luck. After live stream was done and restarted vmix AND then the vmix computer, NDI worked again fine.
Anyone with any ideas?
.... Stream was into its second hour when this occurred.
mavik
#2 Posted : Monday, December 12, 2022 5:29:14 PM(UTC)
mavik
I use vMix preset with NDI source and by the time the source becomes available vmix picks it up. That said it seems it more related to the far end. Have you checked with NDI monitor to see if it's available generally while vmix shows no image.
You also said you needed to restart the vmix computer. That points to an issue with that computer. Try to check the windows event logfor when it went nuts and see if there are some hints.
