Simple Math for Sports Scoreboard
 Any help would be greatly appreciated! Situation: I have an XML-powered scoreboard graphic. If you know a little about basketball, it's nice to be able to show percentages. Unfortunately, the XML generated by my stats program does not put out a percentage field. 😓 Question: In either the Title Editor or GT Title Designer, is there a way to automate some simple math so I can have one field in the XML field divided by another field? Thank you! Sample File: https://www.dropbox.com/...m3vkwor/example.xml?dl=0Would love to automate fgm="16" divided by fga="61" to output 26.2!
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: thenickrobinson  Situation: I have an XML-powered scoreboard graphic. If you know a little about basketball, it's nice to be able to show percentages. Unfortunately, the XML generated by my stats program does not put out a percentage field. 😓 Question: In either the Title Editor or GT Title Designer, is there a way to automate some simple math so I can have one field in the XML field divided by another field? Thank you! Sample File: https://www.dropbox.com/...m3vkwor/example.xml?dl=0Would love to automate fgm="16" divided by fga="61" to output 26.2! Sae answer as given on FB ;-) Small script reading the values from a (invisible) title field where the original values are stored , do calculation and write to a visible title field Alternativly write a script/app to convert the xml by adding values based on the calculations and using the resulting file as a data source (more elaborate)
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 87 time(s) in 67 post(s)
As Doggy described it, let's assume you have a GT Title name: simplemath.gtzip This GT Tile has the fields: fga.Text fgm.Text result.Text The fields fga and fgm are filled in by the XML database. Then you run a small script in vMix, which then gets the two values and fills the result into a third field. Attention: Textfields in scripts are casesensitive Code:dim fgm,fga,result as double 'defines 3 number values
do while true
fga = cint(Input.Find("simplemath.gtzip").Text("fga.Text")) 'gets value fga from the title
fgm = cint(Input.Find("simplemath.gtzip").Text("fgm.Text")) 'gets value fgm from the title
result = (fgm/fga *100).ToString("F2") 'calculates the result with 2 decimals
Input.Find("simplemath.gtzip").Text("result.Text")=result 'writes result back to the title
sleep (500) 'waits a while, can be adjusted (500 = 1/2 second)
loop
