rbsdapateam
#1 Posted : Friday, December 9, 2022 3:27:28 AM(UTC)
rbsdapateam
I am trying to setup a simple trigger. I have an image file as input 7. I want to trigger a fade after a 5 second (5000 millisecond) delay to a video that I have at input 5. I have selected "OnTransitionIn" as the trigger, "Fade" as the function "5-Mission Spotlight" as the input, "500" as the duration, "5000" as the delay.
But when I transition in the image, nothing happens, it just stays on the image. I have tried many different configurations of the above options, including using different images, different inputs, different triggers, but nothing seems to be working.
I have the Max version of vMix.
elvis55
#2 Posted : Friday, December 9, 2022 4:14:54 AM(UTC)
elvis55
Switzerland
Input - ActiveInput
nikosman88
#3 Posted : Friday, December 9, 2022 6:09:33 AM(UTC)
nikosman88
Greece
Yes you`re right or also i cant understand something. Trigger fade doesnt seem to work but if for example we want to overlayin another video,it works ok! I dont understand something me too?
But another way to do this you want is with a simple script as you have max version. You can to go to scripting and put this
sleep 5000
Function=Fade&Input=5&Duration=500&Mix=0
and save it with your desired name
Then you go to your image and you create a trigger-->on transitionin -->scriptstart-->nameofyourscript delay 0 and you`re ok
thanks 1 user thanked nikosman88 for this useful post.
elvis55 on 12/14/2022(UTC)
dmwkr
#4 Posted : Friday, December 9, 2022 6:17:56 AM(UTC)
dmwkr
https://www.vmix.com/help25/Triggers.html
"Note that in order to prevent loops, transition effects have no effect for OnTransitionIn or OnTransitionOut."
thanks 1 user thanked dmwkr for this useful post.
nikosman88 on 12/9/2022(UTC)
elvis55
#5 Posted : Friday, December 9, 2022 6:43:27 AM(UTC)
elvis55
Switzerland
Create a video with the image using a video program, e.g. 5 seconds
OnCompletion (applies to video, list, photos and powerpoint inputs when they reach the end assuming Loop is not enabled).
