Joined: 12/12/2018(UTC) Posts: 23  Thanks: 1 times Was thanked: 8 time(s) in 6 post(s)
It would be handy if there was a label to the right of the "PlayList" button that showed which playlist is currently selected, whether or not a playlist is currently playing. Similar look to the recording time label next to the Recording button.
 1 user thanked cookdoeyl for this useful post.
Can I get a bump on this one, and does anyone agree with it? I never know which playlist is selected at a glance. Having a label of the Selected Playlist name next to the Playlist button would be fantastic.
Is there no one that sees the benefit to this? Being able to glance at the bottom bar and see which Playlist is selected instead of clicking on the gear?
If I can't get that, can I get an API feedback item so at least Companion/Stream Deck can change a button color?
Joined: 12/27/2012(UTC) Posts: 5,522  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: cookdoeyl  Is there no one that sees the benefit to this? Being able to glance at the bottom bar and see which Playlist is selected instead of clicking on the gear?
If I can't get that, can I get an API feedback item so at least Companion/Stream Deck can change a button color? If it's really that important one can retrieve a list of playlists and the current selected one from one of the innerxml's within the Last.vmix preset file (only updates every minute though) with a script
I've never looked into the Last.vmix file, but that minute might be tough to utilize in a quick environment.
Originally Posted by: cookdoeyl  I've never looked into the Last.vmix file, but that minute might be tough to utilize in a quick environment. Last preset is one that autoupdates, a specified one is one the user updates ;-)
