Feature Requests
Add "Overlay 2" and 1.3.4 to Input dropdown
Joined: 3/31/2020(UTC) Posts: 9  Location: Bloomington Thanks: 4 times
Please add "Overlay 2" and 1.3.4 to Input dropdown in the shortcut creator dialogue box I need a way of operating the advancement of overlayed slides independent of what is in Preview or what input number I have overlayed. This is basic functionality and extremely frustrating that I can't do it without having the input in Preview. Preview should be for what goes next on the base layer of Program not where you control the overlayed slides. As it is, every time I switch in a new input to the main program channel the preview gets replaced, removing the controls of the overlay slides. I assume that adding the ability to create a shortcut for any of the four overlay channels will be the easiest way to add this functionality.
Also some way of more easily giving feedback would be helpful. THis was quite a hassle.
Thanks for all you do with this product, generally quite good.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
You could use a trigger to set one of the Dynamic Inputs to your overlayed input and create shortcuts for the Dynamic Input.
 1 user thanked dmwkr for this useful post.
Thanks, that may (or may not) be worthwhile doing. Some means of enabling the functionality more directly would be the obvious solution, perhaps someone might come up with an even better way than what I suggested. I just know there is some serious functionality missing in this regard.
Feature Requests
