I have a custom 2x2 multiview input for 4 inputs. Can I use a script to dynamically change the border color of each layer?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: brianburks  I have a custom 2x2 multiview input for 4 inputs. Can I use a script to dynamically change the border color of each layer? There is no (shortcut)function to do so Alternativly use a (title)rectangle behind and use setcolor function (rectangle.fill.color) to change
Originally Posted by: doggy  Originally Posted by: brianburks  I have a custom 2x2 multiview input for 4 inputs. Can I use a script to dynamically change the border color of each layer? There is no (shortcut)function to do so Alternativly use a (title)rectangle behind and use setcolor function (rectangle.fill.color) to change .
Thanks so much for the help. Your solution is perfect for what I need. I can't seem to find or figure out the correct API call. I can change text box values but not background color. This is one of my attempts: http://192.168.1.236:8088/api/?Function=SetColor&Input=4rectangles&SelectedName=Rectangle2.Fill.Color&Value=#80FF00. My input name is 4rectangles. My rectangle is Rectangle2. Any chance you could help me out one more time?
Thanks so much for the help. Your solution is perfect for what I need. I can't seem to find or figure out the correct API call. I can change text box values but not background color. This is one of my attempts: http://192.168.1.236:8088/api/?Function=SetColor&Input=4rectangles&SelectedName=Rectangle2.Fill.Color&Value=#80FF00. My input name is 4rectangles. My rectangle is Rectangle2. Any chance you could help me out one more time? Special characters need to be URL encoded SEE............Rectangle2.Fill.Color&Value= %2380FF00Also make sure the rectangle setting of hidden is unchecked (data tab in title designer)
