Joined: 12/27/2012(UTC) Posts: 5,505  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Originally Posted by: Huaba  Hi,
is it possible to set a sleep time in the code area like in the vMix Scripts?
Example: *CutDirect(086b45fa-14d7-4787-a00f-aa1c8be374e3, -1) sleep(500) *API(xx.xx.xx.xx:12400/key/f4?Standard.xml)
THX, Andi Sleep(xxx) sure you can , the rest of the example not so sure as it is written Often a good way to find out is to just try it ;-) check out the scripting for dummies post in this forum!
Joined: 1/12/2021(UTC) Posts: 12  Location: Rosenheim Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
THX, Andi Sleep(xxx) sure you can , the rest of the example not so sure as it is written Often a good way to find out is to just try it ;-) check out the scripting for dummies post in this forum! Sorry, it doesn't work. I mean this area in UTC.
Originally Posted by: Huaba  Sorry, it doesn't work. I mean this area in UTC.  Not a vMix situation then
Originally Posted by: doggy  Originally Posted by: Huaba  Sorry, it doesn't work. I mean this area in UTC.  Not a vMix situation then Sorry, wrong thread... javascript:__doPostBack('forum$ctl03$PostReply','')
