Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Best Hies to Vmix Guys ! we talked alot here (in the forum ) to solve the problem Right to Left Ticker ! as Doggy said there is not such a future in Vmix so will be thankful if list this one in the next version or patch .
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: Winops  Best Hies to Vmix Guys ! we talked alot here (in the forum ) to solve the problem Right to Left Ticker ! as Doggy said there is not such a future in Vmix so will be thankful if list this one in the next version or patch .
When? you can set the direction of the ticker (format tab)
Originally Posted by: doggy  Originally Posted by: Winops  Best Hies to Vmix Guys ! we talked alot here (in the forum ) to solve the problem Right to Left Ticker ! as Doggy said there is not such a future in Vmix so will be thankful if list this one in the next version or patch .
When? you can set the direction of the ticker (format tab) here it was about image contained tickers and in that sample i used a wpf plug in but it was animated thicker and couldn't be reversed , https://forums.vmix.com/...-in-thicker-using-webapi
