GT
read or write gt-title text or pic from remote computer via webapi
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
Hi Guys i need to know if it's possible to read g-title data from remote computer and webapi if it's possible please guide me how ? specially it's texts tnx alot
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Winops  Hi Guys i need to know if it's possible to read g-title data from remote computer and webapi if it's possible please guide me how ? specially it's texts tnx alot
You can access the remote API XML (with its IP) of the other computer with a script and xpath to the correct node and send answer to local title with settext One can also get the data with a datasource that refers to that remote XML file using the correct xpath to get the title info
Originally Posted by: doggy  Originally Posted by: Winops  Hi Guys i need to know if it's possible to read g-title data from remote computer and webapi if it's possible please guide me how ? specially it's texts tnx alot
You can access the remote API XML (with its IP) of the other computer with a script and xpath to the correct node and send answer to local title with settext One can also get the data with a datasource that refers to that remote XML file using the correct xpath to get the title info yes that is , may complain more if possible? tnx
GT
