Joined: 11/16/2022(UTC) Posts: 3  Location: Rtd Thanks: 1 times
I hope i’m in the right place for this question, as I have no idea who’s responsible for the vMix plugin on Elgato’s stream deck.
I have use vMix on Stream Deck in the past on a W10 system, it worked fine. I just got me a W11 system and wanted to install the vMix plugin for my Stream Deck, but it won’t install correctly and won’t turn up in Elgato’s stream deck software after installation.
I read about the Win11 bug in the filesystem. Is this issue related to that and if so, is there a way-around, e.g. by relocating files? Any help would be appreciated.
Thanks in advance, Marco
You have been a member since:: 11/16/2022(UTC) Posts: 1  Location: Portland
I have the same issue with windows 10 since updating Streamdeck software to 6.0.0.17703. Completely removing every bit of Elgato software from hard drive and registry and reinstalling it did not fix. Other plugins will install, but not Vmix. If I click install, it shows a progress bar, then changes to the Uninstall button, but that button does nothing. The next time I open the store, it gives me the install button as if it never installed.
Joined: 11/16/2022(UTC) Posts: 3  Location: Maryland Was thanked: 3 time(s) in 3 post(s)
 1 user thanked causemedia for this useful post.
Joined: 10/27/2020(UTC) Posts: 38  Location: Porto Alegre Thanks: 13 times Was thanked: 2 time(s) in 2 post(s)
I have the same situation... I went to update the Stream Deck software version, and the vMix plugin doesn't work anymore.
Originally Posted by: causemedia  For now I think this is the best to do, remove the latest version and revert to 5.3.3, if I can find it. Thanks! Marco
Joined: 12/27/2012(UTC) Posts: 5,509  Location: Belgium Thanks: 316 times Was thanked: 1020 time(s) in 838 post(s)
Originally Posted by: MarcoNL  Originally Posted by: causemedia  For now I think this is the best to do, remove the latest version and revert to 5.3.3, if I can find it. Thanks! Marco Find it ? its right there in the link ;-)
Originally Posted by: doggy  Find it ? its right there in the link ;-)
Yeah, found it after reading your message on my computer. My mobile didn't show the link :( Thanks again. Marco
Is this fixed yet? If so, do you need the latest vMix version for that? I believe the plugin mentioned v22 and up, I tried last week with 24.0.0.72 (I know, I know haven't gotten time to up it yet...) and 6.0.3 Stream Deck 15 buttons but that did not work.
Reverted to SD 5.3.3 and restored a profile backup to get it working again.
Clearly being Elgato's fault of breaking this with their update, but is there any bugfix coming for this, regarding legacy versions like v24? Or is it like "too bad for you"? :(
Joined: 6/17/2020(UTC) Posts: 15  Location: Rugby Thanks: 11 times Was thanked: 1 time(s) in 1 post(s)
I think it is working but for some strange reason you have to redo all the key numbers. I went through all my shortcuts and actions and redid them and it's all working fine now.
