Vproductions
#1 Posted : Wednesday, November 16, 2022 5:15:23 AM(UTC)
Vproductions
My company is looking to have me create a few custom layouts / virtual sets for our vmix productions.
Where can I find a editor that allows me to create these from scratch or take currently existing layouts / virtual and fully customize them.
I would like to create sets that are similar to those in the below image.
Layouts / 2d virtualsets
Any and all assistance is greatly apprecaited.
mavik
#2 Posted : Wednesday, November 16, 2022 5:34:24 AM(UTC)
mavik
Check the virtual set location and open one and you will find a few images and an xml file. That is a good starting point I guess.
c:\Program Files (x86)\vMix\VirtualSets\
The other options is in the layer section. You can create your own positioning and such and export it as well. This is maybe the more visual way.
nikosman88
#3 Posted : Wednesday, November 16, 2022 6:41:51 AM(UTC)
nikosman88
Greece
For simple 2d custom layouts you can create your own by hand or using this tool https://layouts.heretorecord.com/?mode=vmix also you can buy some ready virtualsets. Personally im very happy from this https://payhip.com/b/7xXF it really saved me and for more professional things you can also look here www.vplus.es
