"Use VMR" under Add Input/Capture tab - what does it do?
Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
what does this option in vMix10? is this "virtual genlock" from vMix9?
Thanks: 13 times Was thanked: 3 time(s) in 3 post(s)
Martin Could you answer this question? I am unable to get version 10 to recognize my camera unless I check this box use VMR. Greg
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Hi Greg,
What camera are you using? VMR should not be used unless instructed to do so by support, it is used for diagnosing some issues.
Martin vMix
Martin I guess I should try some more testing. Tonight was the first time I tried to use a camera in vmix since I updated to version 10. I think that I had to put the input on SDI and check the vmr box. I am using firewire for both of them. I have two Panasonic cameras and both were the same way. One DVC 30 and PV-GS400
Greg
What happens when it is left unticked?
One time it give a message about no dv link. Other times the video was blank but there was audio. I will try again this afternoon.
Martin I tried the two cameras this afternoon and they both were seen by Vmix. I am guessing it was a glitch in windows. I restarted Vmix a couple of times but it didn't work but I didn't restart the PC. Sorry for the false alarm. Thanks for the help.
Greg
Hi Martin,
What does the abbreviation VMR mean?
tks
