Shortcut issue when doing DataSourceSelectRow function
Joined: 5/16/2020(UTC) Posts: 38  Location: Trondheim Thanks: 2 times
I've connected my vmix project to a google sheet. It holds information like shirt numbers and names of players and is used for streaming live sports. I have connected this setup to a streamdeck for easy use.
When I press a shortcut that uses the DataSourceSelectRow function vmix is resetting all info to whatever is in the excel sheet. Is it possible to avoid this?
It is creating problems because in my case it means other info like the score in the game is also reset to 0-0 every time we are using this shortcut to read a new player name.
Thanks: 4 times Was thanked: 8 time(s) in 7 post(s)
If you are getting all your data from a single datasource then you need to make sure that every row from your datasource has the correct data. As all titles connected to it will get updated.
Thanks: 64 times Was thanked: 158 time(s) in 142 post(s)
In the Title Editor it is possible to map the field to a single row of your data source, if you choose something else than 'Selected'.
