Joeboe
#1 Posted : Thursday, November 10, 2022 4:52:05 AM(UTC)
Joeboe
Hi all, long time since I asked a question on vMix......
I want to know ...is there a way to have all my inputs ONLY on one scree....I aske this as I want to have all my inputs visible for a client, so they can select the inputs they want me to switch to, ...no need for preview monitor or program monitor, as I will be using fullscreen and output only.....
#2 Posted : Thursday, November 10, 2022 6:10:20 AM(UTC)
Custom mutiview(s)
btw What is "all my inputs" ?
montyfabio
#3 Posted : Thursday, November 10, 2022 6:12:07 AM(UTC)
montyfabio
Italy
what do you mean by "select the input"?
the client has to "click" on the input or just tell you something?
the easiest is a custom multiview but i don't know HOW MANY inputs you have to put on
Joeboe
#4 Posted : Thursday, November 10, 2022 8:30:37 AM(UTC)
Joeboe
What I need is just the camera inputs only, so that the client only sees the cameras....The client is doing the directing, and it is a cuts only shoot....Overlays, etc, will be controlled from the vMix main GUI...I tried the regular multi-view, but the client does not want to be distracted with the preview and output windows.....just inputs....all I am doing is switching the inputs as he calls them, and there is a monitor for full screen output, that he will be using to see what is live, ...NO preview....we are using about 7 or 8 cameras, 1 Zoom input, some clips, which I have in a multi player (play List), ....I am also using Panel Builder on a tablet in front of the multi-view monitor, so the actual vMix PC, is maned by another person ... I understand the client's request, as he is not quite a real producer, but has some knowledge.....the worse ones to work with....
montyfabio
#5 Posted : Thursday, November 10, 2022 8:48:22 PM(UTC)
montyfabio
Italy
it seems pretty simple.. you need a custom multiview
ad an input "color"
then click on the "gear" icon of that input.. Multiview.. you choose the style on the right and on the left you put every camera you need.. up to 10 cameras
then you go to settings.. outputs / NDI.. on your client "fullscreen" put the input multiview you just generated.. so on your client monitor will see the multiview with the camera
thanks 2 users thanked montyfabio for this useful post.
Joeboe on 11/10/2022(UTC), elvis55 on 11/10/2022(UTC)
