Thanks: 1 times Was thanked: 32 time(s) in 10 post(s)
UPDATES Build: 22/04/2022 00:04 -Added button for resetting trim in and out on Properties Window -Added checkbox to update multiple selected rows on Properties Window You are now able to update properties for multiple row: select first item then hold the SHIFT and CONTROL key to select multiple items keep holding on the SHIFT and CONTROL and double click the column of any of the selected rows to open the property editor Click the checkbox next to the fields you wish to update. Note: retiming is calculated from the first item selected you can also use CONTROL key only if you wish to select that way . This Tutorial is very informative and will change the way you think about 24/7 scheduling.download from https://www.vfxblend.com
 1 user thanked vfxblend for this useful post.
Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Terrible, raw software. Unfortunately had the experience of buying it. It just crashes if the playlist contains data for 2-3 days. This is far from the release that the author boasts about. This is at least a beta version that should be distributed for free, not sold. This software should not be used in production. His maximum is house parties.
