zheng1112
#1 Posted : Monday, October 31, 2022 5:01:16 PM(UTC)
zheng1112
China
help, I set a global shortcut key F3 in the "zoom". How to trigger the key F3 when vmix switches a specified material, so that the "zoom" can trigger the event.
I tried to set keypress in the vmix trigger. It only works for vimx.
The above information comes from Baidu Translation
pzaul
#2 Posted : Monday, October 31, 2022 8:34:52 PM(UTC)
pzaul
I have used the AutoIT language to create a small GUI app with buttons to do this. When you click a button in this app, the app changes focus to vMix window, then sends the "F3" key, then changes focus back to the app window. With basic coding skills, AutoIT is relatively easy to create something like this. You might be able to do it better in Python or C or another language that you are fluent in.
zheng1112
#3 Posted : Tuesday, November 1, 2022 1:56:51 PM(UTC)
zheng1112
China
Thanks for pzaul's reply, but I want to execute F3 on the keyboard when playing a certain material in the vmix window.
I see a script option in vmix settings, which can implement similar code:
Console. WriteLine("Hello World")
Can I simulate pressing F3 on the keyboard in the script?
#4 Posted : Tuesday, November 1, 2022 4:59:41 PM(UTC)
Check the Sendkeys and/or Keypress functions (shortcuts/Scripting)
