WesleyFernandes
#1 Posted : Wednesday, October 26, 2022 7:59:14 AM(UTC)
WesleyFernandes
Brazil
Was thanked: 12 time(s) in 5 post(s)
I would like an explanation about the new shortcuts, I confess that I was waiting for many others that have already been mentioned here in the forum by several users.
New Replay shortcuts:
- ReplayMarkInOutLiveFuture,
- ReplaySetChannelAToBTimecode,
- ReplaySetChannelBToATimecode,
- ReplaySetTimecode.
#2 Posted : Wednesday, October 26, 2022 8:22:47 AM(UTC)
Check the "Shortcut Function Reference" in the vMix User Guide
WesleyFernandes
#3 Posted : Wednesday, October 26, 2022 11:58:44 PM(UTC)
WesleyFernandes
Brazil
Hey bro! Sorry but my question was not that friend, I want to know the real need for these shortcuts and so many others could be incorporated.
montyfabio
#4 Posted : Monday, October 31, 2022 11:54:36 PM(UTC)
montyfabio
Italy
actually there's not references to those new shortcuts...................
#5 Posted : Tuesday, November 1, 2022 12:36:29 AM(UTC)
Screenshot 2022-10-31 153352.jpg (58kb) downloaded 3 time(s).
Screenshot 2022-10-31 153523.jpg (123kb) downloaded 2 time(s).
WesleyFernandes
#6 Posted : Thursday, November 3, 2022 3:36:27 AM(UTC)
WesleyFernandes
Brazil
Hello friends, my objection is actually a question, as there are other shortcuts that have already been requested here on the forum, shortcuts that are really necessary and have not been applied in vMix Replay.
Here is a possible list of new shortcuts needed:
- Go To: When you activate this shortcut it takes you to the timecode in or out of the selected event or last, important to make the adjustment using the shortcut UpdateInPoint and UpdateOutPoint.
-> ReplayGoToInPointSelectedEvent
-> ReplayGoToOutPointSelectedEvent
-> ReplayGoToInPointLastEvent
-> ReplayGoToOutPointLastEvent
- JogWheel On/Off Toggle: Leaving the JogWheel OFF when Play is triggered to avoid accidentally touching the Jog and pausing the clip currently playing. As with other replay hardware that avoids this accident. This shortcut could work alone (manual on/off) or linked to PlayPause, PlaySelected, PlayLast, PlayAll, PlayByID (automated).
-> ReplayJogWheelToggle (checkbox option "activate on play")
- SelectMultipleEvent(clips): Shortcut that is activated allows you to select multiple clips as is done using CTRL or Shift on the keyboard, but a shortcut that makes it possible to use a midi controller with this function and thus not use mouse and keyboard in operations.
-> ReplaySelectMultipleEvent: Just like CTRL + mouse click.
To select all the events of the tab (playlist) there is already PlayAll.
These are my suggestions, there are more options that would also be interesting to have as already posted on the forum.
thanks 1 user thanked WesleyFernandes for this useful post.
eduardocfs on 11/3/2022(UTC)
#7 Posted : Thursday, November 3, 2022 5:20:42 PM(UTC)
Was thanked: 4790 time(s) in 1644 post(s)
Have you posted these to Feature Requests?
I did a quick search of some of the functions you proposed and did not find them there.
Please note we can't consider feature requests unless they are submitted to the appropriate forum and people reply in support.
This is the only fair way to add shortcuts in our view.
What one person things are important for one user may not be for another.
thanks 3 users thanked admin for this useful post.
eduardocfs on 11/3/2022(UTC), WesleyFernandes on 11/3/2022(UTC), tjbruce17594 on 5/12/2024(UTC)
WesleyFernandes
#8 Posted : Thursday, November 3, 2022 11:50:35 PM(UTC)
WesleyFernandes
Brazil
Hello Mr. Martin.
I'll post it right now, I'm in contact with several replay hardware and analyzing their functionality and what is within the possible to be applied in vMix.
grateful to help
