For some time I have had a problem with the production clock and as you will see in the video capture, it is not displayed correctly and I cannot use it in my recordings that I use and I need to know how long I have been in my production Video Video captureImage
Joined: 12/27/2012(UTC) Posts: 5,424  Location: Belgium Thanks: 308 times Was thanked: 996 time(s) in 826 post(s)
Originally Posted by: mamomo  For some time I have had a problem with the production clock and as you will see in the video capture, it is not displayed correctly and I cannot use it in my recordings that I use and I need to know how long I have been in my production
If you choose a red background for your clockframe (how did you do that ? ) then no wonder that for example on can not see the recording cock as that is in a red font too BTW: still on trial ?
I have not changed anything, that red background appears automatically, I have deleted all the previous configurations, reinstalled and I am using the 60-day demo.
But for some reason that red box appears on top or replaces the numbering.
What is this ?  Screenshot 2022-10-19 094228.jpg (16kb) downloaded 1 time(s).
That's it display fusión, If I remove it, the same thing still happens, anyway, before I saw it well and I already had this added
Originally Posted by: doggy  What is this ?
After your question I have thought that maybe it is another application that is in memory and I have closed everything, I have restarted VMIX and the same thing continues to happen.
What happens if you check/uncheck the inverted option? What happens if you create an input of it ? What was the response of vMix support ?
Originally Posted by: doggy  What happens if you check/uncheck the inverted option? What happens if you create an input of it ? What was the response of vMix support ? If you watch the video that I have put, you will see that I have tried the option to invest and the same thing continues. I haven't really contacted support, I thought that the best option is here...
As it appears no one else has experienced a similar issue i do believe contacting vMix support is the best option here. Keep us posted
Yes, I have already sent the query to them, when they give me a positive solution, I will bring it here.
According to them, the only possibility is to format
At the moment I am not going to format, the equipment is going very well with the current configuration, I would have to install and configure many things.
I would just like to know how to install everything, everything vmix, system registry and any residue, in principle I have already done it, but this problem keeps happening.
