66 Pages«<5960616263>»
kevev
#1201 Posted : Friday, July 29, 2022 9:22:46 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
@elgarf Is there a way to have UTC control individual audio channels? I have a USB ASIO audio interface pulling in 4x XLR microphones. In vMix I can add this ASIO device as 1 input source with 4 audio channels. I am wondering if I can have 4 audio sliders for controlling these channels individually. Thanks in advance! :)
kevev
#1202 Posted : Monday, August 1, 2022 12:07:00 PM(UTC)
kevev
It looks like vMix API does support these sliders. @elgarf, any chance you can add this?
babird88
#1203 Posted : Monday, August 22, 2022 3:10:18 PM(UTC)
babird88
Title Controller Keeps crashing when trying to save controller after adding the External Data (NDI Monitor)
Darkstr_ker
#1204 Posted : Thursday, October 20, 2022 1:50:01 AM(UTC)
Darkstr_ker
Canada
Hello, thank you for this amazing piece of software. Unfortunatly I can't seem to open my controller I get this error message when trying to open:-
InvalidOperationException: There is an error in XML document (2, 51715). ---&gt; System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: DataProviderContent, vMixControl, ArrayOfVMixControl, Controls, Root. Line 2, position 51715.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String arg)
at System.Xml.XmlTextReaderImpl.ThrowUnclosedElements()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlReader.ReadString()
at System.Xml.XmlTextReaderImpl.ReadString()
at System.Xml.XmlReader.ReadElementString()
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read23_vMixControlExternalData(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read40_vMixControl(Boolean isNullable, Boolean checkType)
at Microsoft.Xml.Serialization.GeneratedAssembly.XmlSerializationReaderObservableCollection1.Read41_ArrayOfVMixControl()
--- End of inner exception stack trace ---
at System.Xml.Serialization.XmlSerializer.Deserialize(XmlReader xmlReader, String encodingStyle, XmlDeserializationEvents events)
at vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings&amp; windowSettings)
at vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings&amp; windowSettings)
P.S. Don't be afraid, your controller is OK.
Report about it on forum.
Log states:-
2022-10-19 08:07:31.7590 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
at System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.EnsureConstructorDelegate(XamlTypeInvoker type)
2022-10-19 08:07:31.7910 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
at System.Xaml.Schema.XamlTypeInvoker.DefaultCtorXamlActivator.CreateInstance(XamlTypeInvoker type)
at System.Xaml.Schema.XamlTypeInvoker.CreateInstance(Object[] arguments)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstanceWithCtor(XamlType xamlType, Object[] args)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CreateInstance(XamlType xamlType, Object[] args)
2022-10-19 08:07:31.8810 INFO 4.0.30319.42000
2022-10-19 08:07:31.8950 INFO Microsoft Windows NT 6.2.9200.0
2022-10-19 08:07:31.9030 INFO Worker Threads:Completion Pool Threads - 1023:1000
2022-10-19 08:07:31.9140 INFO Loading mapped functions.
2022-10-19 08:07:31.9610 INFO Loading templates.
2022-10-19 08:07:32.2980 INFO Searching for data providers.
2022-10-19 08:07:33.4460 INFO Loading window settings.
2022-10-19 08:07:33.4850 INFO Loading variables.
2022-10-19 08:07:33.6670 INFO Checking for updates
2022-10-19 08:07:33.7990 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-10-19 08:07:33.8090 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-10-19 08:07:34.0580 ERROR First Chance exception. System.Net.WebException: The request was aborted: The request was canceled.
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
2022-10-19 08:07:34.0580 ERROR First Chance exception. System.ObjectDisposedException: Cannot access a disposed object.
Object name: 'System.Net.Sockets.NetworkStream'.
at System.Net.Sockets.NetworkStream.EndRead(IAsyncResult asyncResult)
2022-10-19 08:07:34.0750 ERROR First Chance exception. System.Net.WebException: The request was aborted: The request was canceled.
2022-10-19 08:07:34.0860 ERROR First Chance exception. System.ObjectDisposedException: Cannot access a disposed object.
at System.Net.Sockets.NetworkStream.get_InternalSocket()
2022-10-19 08:07:34.0860 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled.
at System.Net.WebClient.GetWebResponse(WebRequest request, IAsyncResult result)
at System.Net.WebClient.DownloadBitsResponseCallback(IAsyncResult result)
2022-10-19 08:07:34.1110 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled.
2022-10-19 08:07:58.2899 INFO Saving controller.
2022-10-19 08:07:58.4439 INFO Writing widgets.
2022-10-19 08:07:58.4439 INFO Writing window settings.
2022-10-19 08:07:58.4659 INFO Writing global variables.
2022-10-19 08:07:58.4809 INFO Controller loading.
2022-10-19 08:07:58.4909 INFO Loading widgets.
2022-10-19 08:07:58.5749 ERROR First Chance exception. System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: DataProviderContent, vMixControl, ArrayOfVMixControl, Controls, Root. Line 2, position 51715.
2022-10-19 08:07:58.5879 ERROR First Chance exception. System.InvalidOperationException: There is an error in XML document (2, 51715). ---> System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: DataProviderContent, vMixControl, ArrayOfVMixControl, Controls, Root. Line 2, position 51715.
2022-10-19 08:07:58.5879 ERROR Error while loading controller! System.InvalidOperationException: There is an error in XML document (2, 51715). ---> System.Xml.XmlException: Unexpected end of file has occurred. The following elements are not closed: DataProviderContent, vMixControl, ArrayOfVMixControl, Controls, Root. Line 2, position 51715.
at vMixController.Classes.Utils.LoadController(Stream stream, IList`1 functions, MainWindowSettings& windowSettings)
at vMixController.Classes.Utils.LoadController(String fileName, IList`1 functions, MainWindowSettings& windowSettings)
2022-10-19 08:07:58.6609 INFO Configuring fabrique to 127.0.0.1:8088.
2022-10-19 08:19:04.0506 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-10-19 08:19:04.0596 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
I wqould appreciate some help deciphering this.
Henrik
#1205 Posted : Wednesday, October 26, 2022 1:53:33 AM(UTC)
Henrik
Germany
Hi all,
I am looking for a working APi command or the correct string for an UTC button to adjust (8 or 6 seconds), start and reset a countdown that will display also the tenth of a second. UTC can handle tenth of a second in its time widget, but I just need the butons "adjust", "start" and "reset". Anybody an idea?
Many Thanks!
illpicasso
#1206 Posted : Tuesday, November 8, 2022 10:34:18 PM(UTC)
illpicasso
Good day! I cant get UTC Controller to open
Log:
2022-11-08 07:23:27.2547 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:27.2697 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:27.3127 INFO 4.0.30319.42000
2022-11-08 07:23:27.3127 INFO Microsoft Windows NT 6.2.9200.0
2022-11-08 07:23:27.3127 INFO Worker Threads:Completion Pool Threads - 1023:1000
2022-11-08 07:23:27.3127 INFO Loading mapped functions.
2022-11-08 07:23:27.3427 INFO Loading templates.
2022-11-08 07:23:27.5663 INFO Searching for data providers.
2022-11-08 07:23:28.0710 INFO Loading window settings.
2022-11-08 07:23:28.1010 INFO Loading variables.
2022-11-08 07:23:28.2581 INFO Checking for updates
2022-11-08 07:23:28.3371 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:28.3371 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:28.4641 ERROR First Chance exception. System.Net.WebException: The request was aborted: The request was canceled.
2022-11-08 07:23:28.4641 ERROR First Chance exception. System.ObjectDisposedException: Cannot access a disposed object.
2022-11-08 07:23:28.4641 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled.
2022-11-08 07:23:28.5861 ERROR Dispatcher unhandled exception. System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490)
at System.Runtime.InteropServices.Marshal.ThrowExceptionForHRInternal(Int32 errorCode, IntPtr errorInfo)
at NAudio.CoreAudioApi.MMDeviceEnumerator.GetDefaultAudioEndpoint(DataFlow dataFlow, Role role)
at NAudio.Wave.WasapiOut.GetDefaultAudioEndpoint()
at NewTek.NDI.WPF.ReceiveView.Connect(Source source) in D:\??????\source\repos\elgarf\vMixUTC\NDILibDotNet2\WPF.ReceiveView.cs:line 484
at NewTek.NDI.WPF.ReceiveView.OnConnectedSourceChanged(Object sender, DependencyPropertyChangedEventArgs e) in D:\??????\source\repos\elgarf\vMixUTC\NDILibDotNet2\WPF.ReceiveView.cs:line 473
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp, Boolean preserveCurrentValue)
at System.Windows.Data.BindingExpressionBase.Invalidate(Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.TransferValue(Object newValue, Boolean isASubPropertyChange)
at System.Windows.Data.BindingExpression.Activate(Object item)
at System.Windows.Data.BindingExpression.AttachToContext(AttachAttempt attempt)
at System.Windows.Data.BindingExpression.MS.Internal.Data.IDataBindEngineClient.AttachToContext(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Task.Run(Boolean lastChance)
at MS.Internal.Data.DataBindEngine.Run(Object arg)
at MS.Internal.Data.DataBindEngine.OnLayoutUpdated(Object sender, EventArgs e)
at System.Windows.ContextLayoutManager.fireLayoutUpdateEvent()
at System.Windows.ContextLayoutManager.UpdateLayout()
at System.Windows.UIElement.UpdateLayout()
at System.Windows.Interop.HwndSource.SetLayoutSize()
at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
at System.Windows.Interop.HwndSource.set_RootVisual(Visual value)
at System.Windows.Window.SetRootVisual()
at System.Windows.Window.SetRootVisualAndUpdateSTC()
at System.Windows.Window.SetupInitialState(Double requestedTop, Double requestedLeft, Double requestedWidth, Double requestedHeight)
at System.Windows.Window.CreateSourceWindow(Boolean duringShow)
at System.Windows.Window.CreateSourceWindowDuringShow()
at System.Windows.Window.SafeCreateWindowDuringShow()
at System.Windows.Window.ShowHelper(Object booleanBox)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
2022-11-08 07:23:28.5891 ERROR Current domain unhandled exception. System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state)
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame)
at System.Windows.Application.RunDispatcher(Object ignore)
at System.Windows.Application.RunInternal(Window window)
at System.Windows.Application.Run(Window window)
at vMixController.App.Main()
2022-11-08 07:23:36.7331 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:36.7483 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:36.7901 INFO 4.0.30319.42000
2022-11-08 07:23:36.7937 INFO Microsoft Windows NT 6.2.9200.0
2022-11-08 07:23:36.7937 INFO Worker Threads:Completion Pool Threads - 1023:1000
2022-11-08 07:23:36.7937 INFO Loading mapped functions.
2022-11-08 07:23:36.8202 INFO Loading templates.
2022-11-08 07:23:37.0422 INFO Searching for data providers.
2022-11-08 07:23:37.5233 INFO Loading window settings.
2022-11-08 07:23:37.5533 INFO Loading variables.
2022-11-08 07:23:37.7154 INFO Checking for updates
2022-11-08 07:23:37.7914 ERROR First Chance exception. System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:37.7914 ERROR First Chance exception. System.Xaml.XamlObjectWriterException: No matching constructor found on type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type. ---> System.MissingMethodException: No default constructor found for type 'vMixController.Help'. You can use the Arguments or FactoryMethod directives to construct this type.
2022-11-08 07:23:37.9184 ERROR First Chance exception. System.Net.WebException: The request was aborted: The request was canceled.
2022-11-08 07:23:37.9184 ERROR First Chance exception. System.ObjectDisposedException: Cannot access a disposed object.
2022-11-08 07:23:37.9184 ERROR Error while connecting vMix server. System.Net.WebException: The request was aborted: The request was canceled.
2022-11-08 07:23:38.0355 ERROR Dispatcher unhandled exception. System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490)
2022-11-08 07:23:38.0355 ERROR Current domain unhandled exception. System.Runtime.InteropServices.COMException (0x80070490): Element not found. (Exception from HRESULT: 0x80070490)
swcreative
#1207 Posted : Wednesday, November 9, 2022 4:37:38 AM(UTC)
swcreative
Originally Posted by: elgarf Go to Quoted Post
Universal Title Controller (updated 07.11.2022)
Great to see you are still updating UTC, thanks for your work on this useful app.
Do you have any plans to add the SetColor function for GT titles that was added in Vmix 25? This would let us program buttons to change the colors of shapes in GT titles.
thanks 2 users thanked swcreative for this useful post.
Chircanu on 11/9/2022(UTC), omo on 12/14/2022(UTC)
JAIRODJ
#1208 Posted : Thursday, November 10, 2022 1:50:00 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi.
You can add functions in the text "FUNCTIONS" that accompanies the application, I did so.
Follow the pattern of how the functions are created... (make a copy of this text before modifying it).
tomaszek117
#1209 Posted : Wednesday, November 16, 2022 11:51:35 PM(UTC)
tomaszek117
Poland
Hi.
Can you write for me how it should exaclly look like? i tried to change it from function SetTextColour and from SetImage but in all of them i can NOT see color index in button proporties... It is only Text and Image index. Also what i tried to do i tried to use API to change color but it is not working at all for me, (i'm using API- http://127.0.0.1:8088/api/?Function=SetColor&Input=MyInput&Value=#0033AA22&SelectedName=Name.Fill.Color). When i set up shortcut to change color and im goind to WebControl all is working fine.
Thank you for your answer.
thanks 1 user thanked tomaszek117 for this useful post.
Chircanu on 11/17/2022(UTC)
JAIRODJ
#1210 Posted : Thursday, November 17, 2022 4:08:10 AM(UTC)
JAIRODJ
Hi.
Hi, add this a FUNCTION
<vMixFunctionReference>
<Description>Change Color Object in Title according to Value parameter.</Description>
<Function>SetColor</Function>
<FormatString>Function=SetColor&amp;Value={2}&amp;Input={0}&amp;SelectedIndex={1}</FormatString>
<IntDescription>Index</IntDescription>
<StringDescription>Colour</StringDescription>
</vMixFunctionReference>
tomaszek117
#1211 Posted : Thursday, November 17, 2022 5:23:39 AM(UTC)
tomaszek117
Poland
I have added this code to UTC function file, but unfortunetly it is not working as still i can not see color index, only TEXTs and IMAGEs index so i cannot choose Index where i want to change color...
I think i sould see something with .Fill.Color extend.
JAIRODJ
#1212 Posted : Thursday, November 17, 2022 6:04:51 AM(UTC)
JAIRODJ
I would not know about it, perhaps with the creator of the application.
But the function "works", just manually add the index to which you want to change the color.
Huaba
#1213 Posted : Friday, November 25, 2022 8:16:35 PM(UTC)
Huaba
Germany
is it possible to set a sleep time in the code area like in the vMix Scripts?
Example:
*CutDirect(086b45fa-14d7-4787-a00f-aa1c8be374e3, -1)
sleep(500)
*API(xx.xx.xx.xx:12400/key/f4?Standard.xml)
THX,
Andi
dmwkr
#1214 Posted : Saturday, November 26, 2022 2:33:58 AM(UTC)
dmwkr
Use the native UTC function "Timer". See https://github.com/elgar...ton-widget-and-scripting
thanks 1 user thanked dmwkr for this useful post.
Huaba on 11/28/2022(UTC)
fabfab10
#1215 Posted : Thursday, December 1, 2022 6:20:39 PM(UTC)
fabfab10
Italy
Hello everybody,
is there any chance UTC can work with MIDI buttons (Elgato Stream Deck to be clear) ?
I know i can simulate hotkeys but this way UTC window needs to have focus.
I was wondering if there is a way to trigger a button or a widget in UTC even when focus is somewhere else.
Thank you for your help
baicast
#1216 Posted : Friday, December 2, 2022 12:15:09 AM(UTC)
baicast
Spain
Hello. I have a problem with UTC. I have made a template for basketball in which the roster of the players is in an excel. I have activated in UTC some lists linked with some excel. But as soon as I try to make a change to the list, the UTC crashes.
Can you please help me??
fabfab10
#1217 Posted : Friday, December 2, 2022 6:35:50 PM(UTC)
fabfab10
Italy
I would start here:
If you have any problems, please attach last log to your post. It's in "Documents/vMix UTC/logs" folder.
Also It's better to look at windows event viewer (because crash can be not added to log).
baicast
#1218 Posted : Friday, December 2, 2022 7:01:38 PM(UTC)
baicast
Spain
2022-12-01.rar (16kb) downloaded 7 time(s).
good morning
I attach the last .log file
Thank you
fabfab10
#1219 Posted : Friday, December 2, 2022 7:55:15 PM(UTC)
fabfab10
Italy
good morning
Thank you
2022-12-01 13:56:25.6784 ERROR Failed loading data provider. {0} System.BadImageFormatException: No se puede cargar el archivo o ensamblado 'file:///C:\Users\BAICAST\Desktop\vMixUTC_Donateware (07.02.2021)\DataProviders\._ExcelDataProvider.dll' ni una de sus dependencias. Se esperaba que el módulo tuviera un manifiesto de ensamblado.
Nombre de archivo: 'file:///C:\Users\BAICAST\Desktop\vMixUTC_Donateware (07.02.2021)\DataProviders\._ExcelDataProvider.dll'
en System.Reflection.RuntimeAssembly._nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
en System.Reflection.RuntimeAssembly.nLoad(AssemblyName fileName, String codeBase, Evidence assemblySecurity, RuntimeAssembly locationHint, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
en System.Reflection.RuntimeAssembly.InternalLoadAssemblyName(AssemblyName assemblyRef, Evidence assemblySecurity, RuntimeAssembly reqAssembly, StackCrawlMark& stackMark, IntPtr pPrivHostBinder, Boolean throwOnFileNotFound, Boolean forIntrospection, Boolean suppressSecurityChecks)
en System.Reflection.RuntimeAssembly.InternalLoadFrom(String assemblyFile, Evidence securityEvidence, Byte[] hashValue, AssemblyHashAlgorithm hashAlgorithm, Boolean forIntrospection, Boolean suppressSecurityChecks, StackCrawlMark& stackMark)
en System.Reflection.Assembly.LoadFrom(String assemblyFile)
en vMixController.ViewModel.MainViewModel..ctor()
Something looks wrong with loading the ExcelDataProvider DLL. Also i would NOT use folders with special characters "\vMixUTC_Donateware (07.02.2021)\".
Try downloading that file again and moving everything to a simpler name folder
taurojo
#1220 Posted : Friday, December 9, 2022 7:59:21 AM(UTC)
taurojo
Hi!!!
Is it possible to edit textbox directly? But using text lines with line breaks.
Of the type:
"Petter Jackson
Writer"
With two lines in a texbox.
Guest (14), RM Digital
