Feature Requests
Blur effect for multi-views
Joined: 2/16/2021(UTC) Posts: 4  Location: Pretoria Thanks: 1 times
+1
This effect will be great for using virtual sets to blur reflections on non shiny surfaces for extra realism.
10/10 would use!
Sounds more like a virtual set design issue if the reflection layer is too reflective (UVmap?)
+1
You can pre-render blur on custom virtual studio elements, but obviously not on live feeds.
Sounds more like a virtual set design issue if the reflection layer is too reflective (UVmap?) No, I add things like shadows to my virtual sets shadows are never have rough edges. Reflections also some times needs to be soft, not crisp clear. The transparency doesnt solve this issue. See attached a example of a set I made, If im able to blur the reflections a little bit that would be great.  Capture copy.png (1,098kb) downloaded 3 time(s).
Joined: 3/23/2020(UTC) Posts: 140  Location: Washington, DC Thanks: 41 times Was thanked: 25 time(s) in 17 post(s)
Joined: 5/27/2020(UTC) Posts: 14  Location: Dallas Was thanked: 5 time(s) in 3 post(s)
I'd love this- being able to blur a vertical photo when I layer it to fill the wide screen, without havign to do it in another app, and take up multiple inputs to have the blurred version behind the sharp version woudl simplify things a lot.
Just being able to have a blur filter for any input would be a great assett.
Joined: 12/28/2021(UTC) Posts: 8  Location: London Thanks: 1 times
Originally Posted by: doggy  Check upcomming v26 ;-) A good step but needs improvement. It doesnt blur indepedent any layer but the basic input and layers remain un-blurred. It needs to be layer depedent this effect. Because now you have to blur the input source for any layer. Also it needs a shortcut to on/off this effect in a source input/layer
Joined: 2/23/2019(UTC) Posts: 137  Thanks: 19 times Was thanked: 29 time(s) in 26 post(s)
Originally Posted by: nikosman88  A good step but needs improvement. It doesnt blur indepedent any layer but the basic input and layers remain un-blurred. It needs to be layer depedent this effect. Because now you have to blur the input source for any layer. Also it needs a shortcut to on/off this effect in a source input/layer It is independent as you can blur any layer before combining them. I'd have thought it less common you would want to blur all layers - but you can put it through a mix input if you want to achieve that.
 1 user thanked RichDanby for this useful post.
Feature Requests
