Joined: 10/15/2022(UTC) Posts: 2  Location: Melbourne
Hello, I'm new to Vmix only in the last week, but I've got a system up and running EXCEPT for one final hurdle.
The idea is to have a gathering of musicians performing to a small live audience, (with 2 cameras), as well as a few musicians performing via ZOOM. The event will then be streamed live to a wider Facebook audience.
The event will also incorporate some pre-recorded video content of musicians/participants who might not be unable to attend the event due to timezone problems.
I've had no luck at all with VB Cable sending and capturing ZOOM audio, but eventually, I was able to send Master vMix audio into ZOOM via a NDI Webcam. However... I found the latency between the audio & video was unacceptable.
The solution was to keep the NDI webcam audio, but switch over to the vMix external as the video source into ZOOM. The result was much improved latency.
SO... I'm happy so far, except that I can't get ZOOM Audio into vMix because audio via VB Cable is only sending small interrupted chunks of Garbled Audio.
I also made sure that VB Cable was configured at each end at 48000-16 bits, by adjusting the VB Cable properties using Windows Sound Devices".
Is there another solution or other config options for getting ZOOM audio into vMix.
Thank You, SFG.
MY SYSTEM: Windows Version 10.0.19044 Build 19044 Intel i7-10700F CPU @ 2.90GHz, Cores: 8 32Gb RAM 1TB SSD Focusrite Scarlet 212. LAN = cabled.
Joined: 5/24/2014(UTC) Posts: 46   Location: Brazil Thanks: 54 times Was thanked: 5 time(s) in 3 post(s)
Hi, try to Desinstall and Reinstall VB Cable. Sometimes this make VB Cable functional again.
I've had a lot more luck with this than VB Cables. Not sure why it's less popular to be honest. VB's interface is awful. https://vac.muzychenko.net/en/
Hi Aaron, YES!!1 YES !!! YES!!! I discovered V.A.C. Audio Routing software 3 days ago and it works brilliantly. They too have a free version with "1 cable", but it PERFECTLY suited my needs and worked instantly with clear reliable audio. Folks... I thoroughly recommend Virtual Audio Cable (VAC) from https://vac.muzychenko.net/en/Download "VAC 4.67 Lite (ZIP archive)" if one cable suits your needs. Thanks again Aaron for your reply to this thread. SFG
I've used VoiceMeeter and VB-Audio Cables with vMix for years. No issues at all. Vincent is very good about support, too.
I also have a license for Virtual Audio Cable (VAC.) It's powerful, but cumbersome.
