Feature Requests
Accurate positioning of content
Joined: 2/16/2022(UTC) Posts: 3  Location: Volketswil
The new version of OBS has a very nice feature that allows you to position elements very precisely.  I would like to see this in vMix as well.
Joined: 4/17/2021(UTC) Posts: 11  Location: London Was thanked: 1 time(s) in 1 post(s)
Also I am banging my head every time when I need to rotate something. Currently you need to enter the amount of the rotation you need in radians. Not in actual degrees. Please utilize deg2rad and/or rad2deg in the UI :D So instead of calculating 3.14/4, I can safely write 45 :D  euclid.png (34kb) downloaded 0 time(s).
Joined: 6/5/2020(UTC) Posts: 55  Location: California Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
+1. I definately would like to position a PIP via an integer pixel count instead of a float percentage. Cropping is already done by integer. Zoom x and y, would be good to just put in pixel dimensions, pan x and y, should be pixel offset from 0,0 referenced to the top left. Also agree rotation should be in degrees.
Joined: 12/14/2018(UTC) Posts: 163   Location: Clermont-Ferrand Thanks: 38 times Was thanked: 10 time(s) in 9 post(s)
Feature Requests
