Hawk
#1 Posted : Friday, October 14, 2022 2:20:40 AM(UTC)
Hawk
The host is using a lav mic and transmitter to send his audio out. I am pulling it into vmix through a mackie audio mixer via USB, it comes through just fine
The host is wearing an wireless IFB earpiece to hear the guest, however the Host cannot hear the zoom caller's audio.
The director can hear the zoom caller but the Host cannot.
Where should the host's audio monitor be routed from exactly? How do we get the right mix back to the wireless IFB?
Do we connect the PHONES out on the Mackie to the IFB transmitter input ? How do we get there from here?
nikosman88
#2 Posted : Friday, October 21, 2022 8:03:49 PM(UTC)
nikosman88
Greece
Was thanked: 99 time(s) in 95 post(s)
Try to go to vmix-->settings-->audio outputs and select an audio bus from A to G and to it select the IFB earpiece. Then go to vmix audio mixer and to the zoom audio input select the bus you have for the IFB earpiece
