instudiomedia
#1 Posted : 11 years ago
instudiomedia
Hello guys my intension is to use a computer in the next configuration but i need some opinion from you.
Configuration is:
Dell Precision T3500
MCU - Xeon Quad Core W3530 2.8Ghz 8M Cache, 4.80 GT/s Intel QPI
RAM - 12Gb DDR 3
HDD - 250Gb SATA
GPU - Nvidia GTX650 1GB ( memory )
OS - Windows 7
3 capture cards BMD Decklink mini recorder
The big question is next:
This configuration is capable to run VMIX with 3 cameras in HD 1080, live streaming in HD 1080 and also record the stream with all the function like overlay,video play,green screen,skype call,etc ?
Thank you
vojam2001
#2 Posted : 11 years ago
vojam2001
For system is recommended Samsung 128 GB S840 Pro.
For files and data 2x 4 TB WD Re WD4000FYYZ, 7200 RPM in RAID 0 mode.
250GB is too small.
thanks 1 user thanked vojam2001 for this useful post.
instudiomedia on 6/28/2014(UTC)
instudiomedia
#3 Posted : 11 years ago
instudiomedia
Thank`s vojam2001.The main concern for me is the MCU speed and motherboard.The HDD can be replace after.For the beginning i will stream max 1-2 hours.I also have 2 x 1T external drive USB 3 for storage.If need it i will reduce the resolution from 1080 to 720 to record for long tine.
