get input number and file name via wep api
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
hi bros i need to get a list of all inputs vmix via web API is it possible ? i need to know which input number assigned to which file path in input list by 3rth party playout user invmix. tnx a lot
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Winops  hi bros i need to get a list of all inputs vmix via web API is it possible ? i need to know which input number assigned to which file path in input list by 3rth party playout user invmix. tnx a lot For starters check the API XMl (localhost:8088/api)
Originally Posted by: doggy  Originally Posted by: Winops  hi bros i need to get a list of all inputs vmix via web API is it possible ? i need to know which input number assigned to which file path in input list by 3rth party playout user invmix. tnx a lot For starters check the API XMl (localhost:8088/api) in this time i really beg u brother tnx aloooot and u said for starter ok, then what is for advance? cause i need fullpath of the input file is there any other way to do this ?
