	GT
	Saving Titles
 Joined: 6/2/2021(UTC) Posts: 2  Location: Westfield MA
                Hi! Relative newbie here. I'm constructing a Hymn text overlay with GT Title Designer. No problem constructing the format. I'm willing to manually insert the text for each of four fields. But I want to save each hymn as a separate element. I don't want it's a pre-set. My idea is to create each Hymn as an overlay at home, then (via Google Docs or a memory stick) insert it as part of the next Sunday's preset at the vMix computer at church.
  I can't get around saving each title as a preset. I just want to save that hymn as an element.
  When opening these presets, even using Append for an additional input, I can only append one other preset.
  Eventually we'll use a data source, but our stream team has been using slides for each hymn and I want to keep their learned habits in place, but still have the advantage of the hymn as an overlay over live video, instead of a static slide.
  Thanks!
	GT
	Saving Titles
