JB
#1 Posted : Wednesday, June 25, 2014 12:32:14 AM(UTC)
JB
Hello, I don't know a lot about the different settings in Vmix and need some help.
I'm using Vmix to record our church services. 3 camcorders and using the sound from our mixer board.
Everything looks and sounds fine on the computer, but when I play the recording back there are clicks/pops in the sound just randomly.
I thought it might be the feed from the mixer to the computer, so I recorded the audio in Audacity and the sound is fine.
I thought i would just take the video feed of Vmix and the sound file from Audacity and blend them together in Sony Vegas editing program. However, both files have the same start and stop position yet the files are 2 min different???
any help on this would be much appreciated. It's probably a simple fix I just don't know how.
Here is a log of one of our services if it helps any...
6/22/2014 10:21:25 AM, Version: 11.0.0.66 x64
6/22/2014 10:21:25 AM, Size: 720x480
6/22/2014 10:21:25 AM, System: NTSC 59.94i or 29.97p
6/22/2014 10:21:25 AM, Codec: Microsoft MPEG-2 Encoder
6/22/2014 10:21:25 AM, Format: UYVY 16 1498831189
6/22/2014 10:21:25 AM, AudioDevice: vMix Audio
6/22/2014 10:21:25 AM, AudioFormat: 48000 Hz 16 Bit 2 Channels
6/22/2014 10:21:25 AM, AudioDelay: 0
6/22/2014 10:21:25 AM, RestartInterval: 0
6/22/2014 10:21:25 AM, BitRate: 16
6/22/2014 10:38:26 AM, StartRecording
6/22/2014 1:03:23 PM, StopRecording
6/22/2014 1:03:23 PM, Duration: 02:21:34
6/22/2014 1:03:23 PM, Frames: 254572
6/22/2014 1:03:23 PM, DroppedFrames: 0
6/22/2014 1:03:23 PM, DueToSourceFrameRate: 0
6/22/2014 1:03:23 PM, DueToHardDiskOrCPU: 0
6/22/2014 1:03:23 PM, DroppedSamples: 2
6/22/2014 1:03:23 PM, MissedSamples: 0
6/22/2014 1:03:23 PM, SyncedSamples: 0
6/22/2014 1:03:23 PM, AudioOffset: 20
6/22/2014 1:03:23 PM, AudioDelay: 0
6/22/2014 1:03:23 PM, AudioEngine
6/22/2014 1:03:23 PM, Running: True
6/22/2014 1:03:23 PM, SampleRate: 48000hz 16 Bit
6/22/2014 1:03:23 PM, MixingErrors: 0
6/22/2014 1:03:23 PM, Streams
6/22/2014 1:03:23 PM, Stream0
6/22/2014 1:03:23 PM, Samples: 570747
6/22/2014 1:03:23 PM, Dropped: 10265
6/22/2014 1:03:23 PM, Latency: 2
6/22/2014 1:03:23 PM, Stream1
6/22/2014 1:03:23 PM, Samples: 0
6/22/2014 1:03:23 PM, Dropped: 0
6/22/2014 1:03:23 PM, Latency: 0
6/22/2014 1:03:23 PM, AudioInputs
6/22/2014 1:03:23 PM, Blackmagic WDM Capture
6/22/2014 1:03:23 PM, Latency: 20/67
6/22/2014 1:03:23 PM, Resampled: 0 ms
6/22/2014 1:03:23 PM, Conexant Polaris Video Capture
6/22/2014 1:03:23 PM, Latency: 80/67
6/22/2014 1:03:23 PM, Resampled: 568 ms
redbikemaster
#2 Posted : Thursday, June 26, 2014 7:01:58 PM(UTC)
redbikemaster
I'm just starting out with this software, but I noticed it say you had an audio offset. Could that have been set in your settings?
JB
#3 Posted : Thursday, June 26, 2014 10:29:17 PM(UTC)
JB
I saw that too, if it is set I'm not sure how to fix it??
