Joined: 7/1/2020(UTC) Posts: 103  Location: Earth Was thanked: 23 time(s) in 20 post(s)
So I realized today that soloing an output bus overrides soloing an input. This is the reverse of any audio console I have ever worked on. Would it be possible to change this?
When doing green room busses, or different bus mixes for remote sites, it is necessary to monitor these outgoing feeds, and solo is the only way to do that in vMix. However it is still necessary to check inputs as well. Having to un-solo my output to check an input, then re-solo the bus to hear my feed is very cumbersome. Having the input solo take priority over a bus solo would make life so much easier, and also match what most audio consoles do.
Joined: 2/5/2021(UTC) Posts: 38  Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
I'm not sure this is 100% the case - soloing the bus lets you hear all activity on the bus, soloing an input on that SAME bus lets you hear just that input. Going across busses, Soloing Bus A and then soloing an input on Bus B, will do nothing in the headphone monitor. Are you seeing (hearing) something different?
Maybe there is a different way to setup your buses.
