Salvatore
#1 Posted : Monday, October 3, 2022 7:56:24 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
Hello vmix team.
i‘m very happy about the announcement to expand vmix 26 with further mix inputs.
Can you please change the Input names of the mix inputs on that occasion.
currently the first mix input is named Mix2. the second is called Mix3 etc.
but when scripting, Mix2 is mix=1. that causes confusion
mix= 0: main mix,
mix= 1: first Mix input, rename to Mix1 (and not Mix2)
mix= 2: second Mix Input, rename to Mix2 (and not Mix3) etc.
alternatively, you could also start counting with 1 instead of 0
mix= 1: main mix,
mix= 2: first Mix input named Mix2
mix= 3: second Mix Input named Mix3 etc
but that would mean that all previous scripts and applications would have to be adjusted.
