No title refresh from new data source
Joined: 2/18/2019(UTC) Posts: 59  Thanks: 5 times Was thanked: 2 time(s) in 2 post(s)
Hello!
I have a problem: I have a title with a ranking list. Datasource is a XLS file. Today I have changed the XLS file, identical format, actual data... BUT my title does not refresh and show the new data. Right-click and "Reload" does not work. Only if I go to title editor and change i.e. the name of the driver on P1... i only must open the data source window... and i see the correct name. Why does that not work automatically for all my definitions?
THX in advance for your help
What does this mean Originally Posted by: burie  change i.e. the name of the driver on P1... Did you save the XLS file, same location , same name ,also same description in the data source manager ?
Originally Posted by: doggy  Did you save the XLS file, same location , same name ,also same description in the data source manager ? yep, I've saved the file :) I can see the changes in the data source manager, I have activated the refresh every 1000 milliseconds. But in the title nothing changes. Also if I rightclick the title and then "reload". Originally Posted by: doggy  What does this mean Originally Posted by: burie  change i.e. the name of the driver on P1... rightclick the title -> title Editor on left side scroll to i.e. "Name1.txt". click it... on the right u see the name... Max Miller Unfortunately this is the "old" name. up right click on "DataSource" Then in field "preview" i cann see the "new" and correct name... John Smith But why NOT in the title?
 DataSource Problem2.jpg (268kb) downloaded 14 time(s).This is a screenshot about my problem.... U can see....title is public with the wrong name, but has the right datasource. "Michael Bräutigam" would be correct in the title.
the image shows you need to press OK button first for the setting to take effect
Originally Posted by: burie   DataSource Problem2.jpg (268kb) downloaded 14 time(s).This is a screenshot about my problem.... U can see....title is public with the wrong name, but has the right datasource. "Michael Bräutigam" would be correct in the title. press autonext
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
I want to report this issue with vMix 25.0.0.32.
With GT title and XML data sources, the data in displayed GT title does not match with the underlying data from data sources.
Seen from HTTP API, the data for all GT title fields are correct.
I think this is a serious issue with the reliability.
I think this is a serious issue with the reliability. Update ! also a bit more info would be helpfull
