Systems
Control Media Files Loaded in VMix
Joined: 5/15/2022(UTC) Posts: 39   Thanks: 6 times Was thanked: 1 time(s) in 1 post(s)
As we know the most important thing In broadcast systems are media content to be played in, I did some google searches but couldn't find a complete solution to prevent uncontrolled media playback in VMix Playlists. Is there any survey for this ? For example checking MD5 or file size or check with a 3rd party list then add it to Vmix Panel & Main Playlist?
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Winops  As we know the most important thing In broadcast systems are media content to be played in, Is it ;-) ? Quote: I did some google searches but couldn't find a complete solution to prevent uncontrolled media playback in VMix Playlists.
you mean inputs just play randomly by themselves? Quote: Is there any survey for this ? For example checking MD5 or file size or check with a 3rd party list then add it to Vmix Panel & Main Playlist?
One can always do some vMix scripting to achieve much of this
Good Job dude no not randomly (its like a joke !) but usually the operator is not a SANS Specialist ! THEN we need an storage to provide clean (not injected or poly morphed) media
"One can always do some vMix scripting to achieve much of this" and i need to know how ? using vmix web api ?
Originally Posted by: Winops  "One can always do some vMix scripting to achieve much of this" and i need to know how ? using vmix web api ?
vMix scripting can do more then just use the vMix Api. As per the helpfiles : "vMix Scripting supports the majority of VB.NET 2.0 code that will work within a single sub or function. This means that custom classes and structures are not supported, however you can use the vast majority of the built in base classes in the .NET framework including the handy System.Net.WebClient for downloading data over the internet."when the need arises to be able to have subs and/or functions or libraries loaded within the code an external app instead will let you use the vMix Api too (say using httprequests of the vMix functions) for fileinfo for example vMix vb.net scripting can do it out of the box
Systems
