Feature Requests
Shortcut to Adjust Master (monitoring)Device Volume
I would love a Shortcut to Adjust Master (monitoring) Volume WITHOUT adjusting the master volume to the stream. Under master audio settings, there is device volume where you can adjust the volume of the device your using to listen to the master by adjusting the slider. If there was a shortcut to set this device volume that would be wonderful.
Joined: 11/19/2015(UTC) Posts: 30  Location: Netherlands Thanks: 1 times Was thanked: 3 time(s) in 3 post(s)
+1 i was just looking for this shortcut. I have a novation launch control XL. The top row is set to audio gain, the 3rd row to pan left/right. Would be nice to use the second row for the incoming device volume.
Correct me if I have misunderstood but...
SetVolume
is the Shortcut that can be used for this with any Input in vMix.
If you open audio settings, for some devices (like line-in) you will see the option Device Volume above Gain. This is not the same as SetVolume or SetGain. In case the device volume is set too loud, the audio is already corrupted. So thats where SetDeviceVolume would come in hand.
Oscar
Feature Requests
