Joined: 5/3/2020(UTC) Posts: 35  Was thanked: 1 time(s) in 1 post(s)
I have a Rodecaster Pro II and having a heck of a time getting it to work with vmix. Let me be clear, it works great with Vmix as a mic mixing input - but what I want to do it route the audio back to the RCPII so I can use my headphones with it. Right now I have to plug my headphones into the PC to hear vmix output without an echo.
What is the proper way to set up Vmix and the Rodecaster Pro II so I can both use it as a mic source (for my mic) and also plug my headphones into it to hear what vmix is recording.
I would suggest using busses for that. In the audio output settings you can select what interface to put out the audio on. Simply select your device's options listed.
