How to Move a Nested Multiview across the screen?
Hello All I need to learn how to do a simple "move" in vMix before I upgrade to HD. In OBS I have a scene that uses a plugin to move a nested scene of 2 characters dancing on a platform from left to right: off screen - on - off Each dancer is in a mp4 with greenscreen placed on a png image background - so 3 elements to that scene viewed in the main scene through the missing section of another png with a full screen video in the background. See image below Video link available if wanted. Which "Timed Function" would cause a nested MultiView to move across the screen? I can't figure it out from the videos.  RM.jpg (130kb) downloaded 2 time(s).
Joined: 4/23/2017(UTC) Posts: 1,481  Location: Germany Thanks: 3 times Was thanked: 196 time(s) in 176 post(s)
Have you tried a script positioning the layer
A great way to replicate that OBS plugin (and way easier) is using the Merge transition. Have your input with the Nested Multiview in one side, then duplicate it creating a Virtual input of it, and then alter the position of the Nested multiview. Then use the Merge transition between the two and to make it move between the two positions. You could also make a script, but as if I understood what you wanted to do, that is the easiest way to do it
Cheers
 1 user thanked Idahno for this useful post.
